JamesWoods96's avatar
JamesWoods96
Netgear Powerline 1000v2 Suddenly Stopped Working From Outlet
My Powerline 1000v2 has suddenly stopped working on the outlet next to my computer. I've had it for over a year at this point and had it plugged into my computer for the last 8 months working fine and not changing anything.
As of the last several days, without changing any settings, I have lost my ethernet connection. I have tried factory resetting, and it works just fine on other outlets around the house. But when plugged into the original outlet (that it had been working on until recently) the power light goes on, the ethernet light goes on and the pick a plug light goes on. After several seconds, the pick a plug light goes off.
I'd appreciate any help as I have not seen any solutions to a similar problem.
1 Reply
  • Update, it seems to cut out sporadically, usually in the afternoon, then come back later at night. Since I didn't make it clear before, the pick a plug light turns green for 10 seconds when initially plugged in, then turns off completely.
