JoelReeves's avatar
JoelReeves
Initiate
Aug 18, 2020
Netgear R6300 with backhaul to EX6100
I have had the Netgear R6300 and EX6100 for several years, configured with a wireless connection between the two devices.   I would like to move the extender to a new location and use an existing e...
  • plemans's avatar
    Aug 18, 2020
    I would like to move the extender to a new location and use an existing ethernet cable for the backhaul connection to the router.
    1. What configuration changes do I need to make to the extender?---rerun setup and run it in access point mode.
    (I use the browser based configuration method)
    2. Do I need to turn off the wireless backhaul somehow?---no, rerunning setup and having it in access point mode will take care of it.
    3. Does it just sence it has a cable connection and begins to use it?---see above.
    4. Do I just change the hardware switch to Access Point?----you can just switch it, but i'd redo the setup process to ensure it runs well.
