Hari381
Apr 07, 2016Aspirant
Netgear Ranger extender EX2700 or WN3000RP?
Hello, newbie here My first ever post, I haven't spotted this query anywhere in other posts. I need to buy a ranger extender as I have drop out in my sitting room which is the furthest room a...
Hari381
Apr 08, 2016Aspirant
Thank you for your swift reply.
Having swept the net last night I see that dual band extenders can rise quite steeply very quickly but now I am like a kid in a sweet shop
which one to have.
I see the cheaper end moving upwards as follows, EX3700, AC750, EX6150-100, WN3500RP then at the top end of my budget the Nighthawk7000 can you assist me please. If I went with the Nighthawk 7000 would that be like cracking a nut with a sledgehammer as one of the cheaper ones would do the same job.
Best wishes
Hari
TheEther
Apr 08, 2016Guru
There are a few things to consider:
- The speed of your Internet service. It sounds like it's 20 Mbps.
- The Wi-Fi capabilities of your Bright Box 2. It looks like it's an AC1200 class router.
- The Wi-Fi capabilities of your devices. Are they 2.4 GHz only or dual band?
- The number of Wi-Fi devices.
- Planned uses for Wi-Fi. Will it strictly be for Internet access or also for heavy-duty data transfers between devices at home (e.g. streaming video off of a NAS to a smart TV or laptop)?
- Your budget.
Your answers will determine what you should get. The EX7000 would exceed the capabilities of the Bright Box 2, so it might not be the best choice unless you need the range provided by its large antennas, you plan to perform heavy-duty data transfers, or you just want something that will not be the next bottleneck as you upgrade other components. An AC1200 class extender would match the Bright Box 2. Or you could go lower end if you only plan to do Internet; your Internet service would most likely be the bottleneck. Personally I would not go any lower than any of the AC750 class device since it really pays to take advantage of the 802.11ac capabilities built into the Bright Box 2.
Hope this helps.
- Hari381Apr 08, 2016Aspirant
Good afternoon
Answers to your questions:
- The speed of your Internet service. It sounds like it's 20 Mbps. - Yes EE fibre optic promised 20 Mbps download
- The Wi-Fi capabilities of your Bright Box 2. It looks like it's an AC1200 class router. - Yes I believe this is correct AC1200 class
- The Wi-Fi capabilities of your devices. Are they 2.4 GHz only or dual band? - No it offers both 2.4 GHz and 5 GHz
- The number of Wi-Fi devices. - Smart TV, 2 x Ipads and occasional a laptop
- Planned uses for Wi-Fi. Will it strictly be for Internet access or also for heavy-duty data transfers between devices at home (e.g. streaming video off of a NAS to a smart TV or laptop)? - We want to watch Netflix but that has an app, you tube and possible films/football from the Ipad, Sky Go, Facetime when my children call us.
- Your budget. - upto £100
Best wishes
Hari
- TheEtherApr 08, 2016Guru
Any of the AC750 extenders and a few of the AC1200 extenders would fit your budget. Make your purchase from a place that has a good return policy.
