Ryukyu01
Aug 11, 2019Aspirant
Netgear Router with ORBI MESH SYSTEM
I currently have a Nighthawk R7000 AC1900 router connected to my fiber modem. I have a concrete house and want to try the Orbi Mesh system and want to know the best setup for using both. Do i connec...
Aug 11, 2019Guru - Experienced User
Ryukyu01 wrote:I currently have a Nighthawk R7000 AC1900 router connected to my fiber modem. I have a concrete house and want to try the Orbi Mesh system and want to know the best setup for using both. Do i connect the Orbi to the AC1900 or connect the 1900 to the fiber line modem and then connect the 1900 to that. If i connect the Orbi to the ac1900C i am told i should disable the wifi on the 1900. If i do that can i still use the CAT 5 ports on the back of the 1900 to run cable to the TV.?? THanks.
You're in a tough situation. Concrete does an excellent job of blocking wifi signals. The orbi uses a wireless backhaul to talk between the devices and need 30 ft apart to function properly. You might struggle a bit with the concrete walls in that situation. If you have an option of wired backhual or using powerline/MoCa adapters for the backhaul, it'll perform better.
You can use your R7000 as primary but you're correct in turning off the wifi. You'd also want your orbi in AP mode.
Your other option is to remove it entirely. the orbi is really capable and the r7000 isn't needed unless you just need the ports. In that case, I'd recommend a simple switch. I'm a fan of reducing complexity because simplier setups, tend to be more stable and have less issues. Just my thoughts a little on the subject.
