Boberto54
May 27, 2021Initiate
Netgear Router/Mesh wifi
I have a Netgear C7100V Cable Modem router. Im considering purchasing a AX1800 WiFi Mesh Extender (EAX20) NETGEAR® Dual-band WiFi 6 Mesh Extender, 1.8Gbps Can anyone tell me if these two devices ...
May 27, 2021Guru - Experienced User
will it work with the C7100v?
Yes. it'll work.
But I'd also consider the EX7500.
Its on sale on amazon for cheaper (currently), would have the same performance (if not a little better) than the eax20, and has the dedicated backhaul so would have lower latency.
- Boberto54Jun 04, 2021InitiateThank you for the reply and suggestion.
