Curlie028
Jul 31, 2021Star
NETGEAR Tri-band Wireless Mesh WiFi Internet Booster Range Extender Installation Help Needed
Bought this extender just before Christmas 2020 because all reviews suggested it was easy to set-up and delivered great results but that couldn't be further from the truth for me. A little backgroun...
Curlie028
Aug 01, 2021Star
Thanks again plemans.
I got into the app this morning and set it up but as I guess you were predicting it just interferred and reduced my connectivity again.
I'm sure I will have a cable that fits somewhere in the house.
Am I correct to say I use USB to connect it to the Macbook?
Aug 01, 2021Guru - Experienced User
No, you can't connect the macbook via usb to the EX8000 unless you have a usb---ethernet adapter.
