K4955
Oct 15, 2021Aspirant
NETGEAR USB control Center-EX6200/AC1200
NETGEAR USB Control center app installed in my PC.does not show any printer Model: EX6200|AC1200 Dual Band WiFi Range Extender
michaelkenward
Oct 16, 2021Guru - Experienced User
It won't. Once installed, forget the USB Control center.
Not knowing what you are doing, it is impossible to say much more than that.
Do you have a problem with the printer?
Does the printer show in Windows?
- K4955Oct 17, 2021Aspirant
Do not have a problem with the printer, which is shared in Windows 10 64 bit, configured as a network printer using static IP address. The printer and scanner due to multi function is visible under basic Microsft Scan program as well as HP Scan & Capture, due to USB cable connected directl to PC. I can print and scan to the existing printer, but want to use the sanning function using NETGEAR Readyshare Printer utility.
- michaelkenwardOct 17, 2021Guru - Experienced User
Maybe this depends on the Netgear device you want to use.
But this bt is puzzling:
That is for a device connected to your EX6200. It isn't for things connected to your PC.
I assume that you have checked the relevant bits in the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
Look for the sections in the manual Install the ReadySHARE Printer Utility and Use the Scan Feature of a Multifunction USB Printer.Is the Model: A6150WiFi USB Adapter listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
Or did you just click the first thing that popped up when you wrote your message? :smileysurprised:
