TheSleeper2006
Jun 16, 2017Follower
Netgear WAC120 - Maintenance Menu Missing after Firmware v2.0.5 update
Netgear Wireless AP Model: WAC120 Firmware: v2.0.5 PC Brand: ASUS PC OS: Windows 10 After doing the firmware update to v2.0.5 the maintenance menu is missing. All I see is the Config menu, it...
DarrenM
Jun 22, 2017Sr. NETGEAR Moderator
Hello TheSleeper2006
Have you tried to reload the firmware?
DarrenM
- NetGodJul 03, 2017Aspirant
Hello,
i have exactly the same problem - WAC120 bought on 26.06.2017, firmware updated to 2.0.5 like advised on the download-page, not directly to 2.1.2.
Reload of firmware is not possible, because the whole menu for doing that is missing, even after reboot and hard-reset.
So if there is another way to reload the firmware we would really appreciate if you would tell us, Darren.
Thanks!
- DarrenMJul 06, 2017Sr. NETGEAR Moderator
Hello NetGod
You may want to try this method.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
DarrenM
