TheSleeper2006
Jun 16, 2017Follower
Netgear WAC120 - Maintenance Menu Missing after Firmware v2.0.5 update
Netgear Wireless AP Model: WAC120 Firmware: v2.0.5 PC Brand: ASUS PC OS: Windows 10 After doing the firmware update to v2.0.5 the maintenance menu is missing. All I see is the Config menu, it...
NetGod
Jul 03, 2017Aspirant
Hello,
i have exactly the same problem - WAC120 bought on 26.06.2017, firmware updated to 2.0.5 like advised on the download-page, not directly to 2.1.2.
Reload of firmware is not possible, because the whole menu for doing that is missing, even after reboot and hard-reset.
So if there is another way to reload the firmware we would really appreciate if you would tell us, Darren.
Thanks!
DarrenM
Jul 06, 2017Sr. NETGEAR Moderator
Hello NetGod
You may want to try this method.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
DarrenM
