BadWap
Dec 12, 2011Aspirant
Netgear WG602v4
I am to configure the device as an end point. The problem is when I go to attach to a network it wants me to specify the country. Well the country setting is grayed out, and I can't connect without it...
jmizoguchi
Dec 14, 2011Virtuoso
if you are joining other existing network using below then I don't think you have option to change. if you as an access point then under wireless setting it will let you
http://interface.netgear-forum.com/WG602v4/wds.html
