BadWap
Dec 12, 2011Aspirant
Netgear WG602v4
I am to configure the device as an end point. The problem is when I go to attach to a network it wants me to specify the country. Well the country setting is grayed out, and I can't connect without it...
jmizoguchi
Dec 15, 2011Virtuoso
BadWap wrote: No, I put it in Client Mode. I want it to act like a very good network card. When I do the site survey and try to join the network it will not allow me to specify a country.
because you going the existing network so there is no reason to pick reason. only uses access point which broadcast the signal from the WG602
