BadWap
Dec 12, 2011Aspirant
Netgear WG602v4
I am to configure the device as an end point. The problem is when I go to attach to a network it wants me to specify the country. Well the country setting is grayed out, and I can't connect without it...
Penry
Jan 03, 2012Aspirant
jmizoguchi wrote: personally I would dump WGXX and go something else. Newer Prosafe AP or other depending on what you need.
Are netgear support likely to offer to replace this model with a newer prosafe AP if they are unable to provide functioning firmware for it ?
Does the Prosafe AP firmware work, or is it likely to have the same failures and be unable to be configured in Client Mode? do it also suffer from a lack of bug fix updates?
Personally, I'm inclined to recomend the owner refuse a replacement if offered, and demand a full refund plus costs. There a plenty of other brands of AP which are known to work as they state on the box, and also have manufacturer provided firmware updates to fix problems like this if they have occured.
