magma
May 27, 2012Aspirant
Netgear WGR614v10 repeating does not work-please help
Hello all i purchased 2 brand new netgear WGR614v10 routers specificallyso i could repeat wifi signal howevr i have been disappointed with the result router1 is connected to my broadband modem...
ggift_1029
May 27, 2012Tutor
The Mode should not be upto 150 mbps. The router is a G-router, so it runs upto 54 mbps only. Plus the security type that you're using is WEP which will provide upto 54 mbps also. And after setting up everything, make sure to do a powercycle to the repeater and router.
