magma
May 27, 2012Aspirant
Netgear WGR614v10 repeating does not work-please help
Hello all i purchased 2 brand new netgear WGR614v10 routers specificallyso i could repeat wifi signal howevr i have been disappointed with the result router1 is connected to my broadband modem...
magma
jmizoguchi wrote: URL is for using ethernet cable between two devices so repeater function setting in the router is USELESS
This repeater setup
http://vpncasestudy.com/download/WDS/WDS_Concept.pdf
Make sure you are using wireless Mac address under router status
what is wireless mac address
my router status shows only two mac addresses
internet port mac address and LAN port mac addresss ( which is the same as the sticker)
i have used the LAN port mac address
ggift_1029 wrote: The Mode should not be upto 150 mbps. The router is a G-router, so it runs upto 54 mbps only. Plus the security type that you're using is WEP which will provide upto 54 mbps also. And after setting up everything, make sure to do a powercycle to the repeater and router.
what is powercylce?
@all
the above leads me to assume that my notebook can communicate with the repeater- which is evident from the "EXCELLENT" signal i receive when i use diff channels ( base and repeater)- (albeit NO internet connectivity)
i think the issue here is that there is no wifi communication between the base and repeater - (internet doesnt flow between them)
what do you guys think is the problem
