Simmo83
Aug 10, 2021Aspirant
NETGEAR WiFi Booster Range Extender EX6120
Hi, I am hoping someone more knowledgable than I can help with this. I have been using the Netgear Wifi-Extender (EX6120) since January with no problems then this morning it decided to kick a...
Aug 11, 2021Guru - Experienced User
What router is it connected to?
Are you installing it using wps or using the installation assistant?
Try factory resetting it, push and hold reset for 7-15 seconds while powered on, then install it using the installation assistant and NOT wps.
