ScottS88's avatar
ScottS88
Follower
Apr 02, 2020
Netgear wifi extender 6400ex
We have a standard router from Armstrong Cable and use netgear wifi extender 6400 ex.
The extender does not give us enough range outside.
I am locating my home office to another building on our property; about 300 feet away from router.
Is there a extender that I should buy that will sufficiently cover the new location?
1 Reply
  • plemans's avatar
    300ft is to far for a standard wireless device. Its even the max distance ethernet is rated to.
    You'd want something like a point to point system. you can search amazon for them or netgear has a version called airbridge
    https://www.netgear.com/business/products/wireless/wireless-airbridge/wbc502.aspx
    if you do somethingg like this though, I'd recommend connecting the airbridge/point-point system directly to the router and not through the range extender. Range extenders drop throughput and increase latency by the very nature of how they work. Its best to start off with the best possible connection.
