robinson03
Mar 12, 2023Follower
Netgear Wifi extender AC750 model #EX3110
We are having trouble connecting the extender to the new router. It will not connect. Any help?
Mar 12, 2023Guru - Experienced User
What router are you connecting it to?
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
