corvairbob
Feb 25, 2024Tutor
netgear wifi extender question
i can't put in the associated product field this extender it will not stay there. i have a netgear router/modem model c3700-100nas and i have out in my back garage 2 ewelink plugin wifi plug type sw...
Feb 25, 2024Guru - Experienced User
that extender is not a mesh extender. So when you connect it and setup its ssid, you need to setup the other switches to connect to it and not the router.
They have to be programmed/configured which ssid (name) to connect to
