haggishopper's avatar
haggishopper
Follower
May 20, 2019
netgear wifi extender wn3000rp v1h2 setup on windows 7
Help anyone, i am trying to add this extender on windows 10 and all i can find is help with xp or 7.  it cant find the extender when i plug it in.  codo i need to ask it to forget the other network? any help gratefully recieved.
thanks
1 Reply
  • Just go to Settings for WiFi. The extender will be listed. Just connect to it using the same passphrase as for your router SSID - no need to 'Forget' the router SSID, Windows10 will connect to the access point with the strongest signal.
