tregnabp
Feb 15, 2024Aspirant
NETGEAR WiFi Mesh Range Extender EX7000
 This issue just started last week and has happened three times since then.  My range extender seems to forget my wifi password.  I try to connect to it and it returns a message that the password is i...
- Feb 17, 2024Yeah, if they're hardwired in, they should be in access point mode. Like you mentioned, they're a lot faster when setup in access point mode/hardwired in. Extender mode cuts their throughput 50% just by how it has to function. Should make your network quite a bit more stable
tregnabp
Feb 16, 2024Aspirant
Thanks for your reply, greatly appreciated.
1. the router is provide by ATT and the model number is BGW210-700 it is in the basement.
2. The EX7000s were added because the WiFi signal was too weak in other areas.
One EX7000 is in the back of our house one story up and maybe thirty feet away,
Another EX7000 is in our unattached garage which is over 50 feet away from the first EX7000
Another EX7000 is in an adjoining building approximately 50 feet way inside that building
This is a star configuration they are not daisy chained to each other all are hard wired connected.
3. This configuration has been working since 2018 with no difficulty. The problem just started about a week ago and has occurred several times.
All EX7000 boxes use the same WiFi id and the same password, this allows me to travel from one area to another and never lose connection. Has been working great for several years.
The additional EX7000 boxes were added because of a weak signal in the other two buildings.
Not familiar with a Mesh configuration but as I said the problem has been working since 2018 without any issues, not sure how one EX7000 could connect to another, they all have a direct ethernet connection to the router.
Feb 16, 2024Guru - Experienced User
So its happened to 2x of the extenders but not the 3rd.
Have you tried swapping them around to see if its a connection issue back to the main router?
What firmware is on the extenders?
I take it they're setup in access point mode?
- tregnabpFeb 16, 2024AspirantActually you make some good points. You are correct, the third one was not failing They were setup in extender mode and the firmware was not current. I have updated the firmware on the two boxes that were failing. The one that is not failing I was not able to update it for some reason, will try that one later since it is working. I have now changed both of the ones that were failing to Access Point and have current firmware. 1. they are much faster and I already had a wired connection at both locations. 2. will now see if they have the issue again in AP mode. 3. Not sure why I had them in extender mode before. Thanks for you assistance, will update this in week if they fail again or they continue to work Thanks for listening. - plemansFeb 17, 2024Guru - Experienced UserYeah, if they're hardwired in, they should be in access point mode. Like you mentioned, they're a lot faster when setup in access point mode/hardwired in. Extender mode cuts their throughput 50% just by how it has to function. Should make your network quite a bit more stable
