Raza_25496
Jun 04, 2020Follower
netgear wirless-N 300
I FORGET PASSWORD I WANT TO REST HOW TO DO I DONT HAVE CD AND CABLE
Jun 05, 2020Guru - Experienced User
1. Caps lock. Its to the left of the "A" key. Please use it.
2. you don't need the cd to install it if you have the dgn2000. go to https://www.netgear.com/support/product/DGN2000.aspx and follow the install guide.
3. if you've forgotten the password and the recover password option doesn't work, simply reset the device back to factory and re-install it. push and hold reset for 7-15 seconds while its powered on. Then re-install it using the guide from step 2.
