dtm320i's avatar
dtm320i
netgear wn2500rp - how to set time limit access?
Hi,
    A newbie and non techy here.
   Can WN2500RP be programmed to set timed or scheluded limited access to internet on certain devices?  If so, would appreciate the step by step assistance.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello dtm320ti
    The extender does not have these type of settings you will have to check your routers manual to see if it has some type of parental controls or wifi scheduled settings in order to do what you are asking.
    DarrenM
