Elaine22
Jul 29, 2020Follower
Netgear Wn2500RP cannot connect time new fibre router
Will my netgear extender work with fibre?
Jul 30, 2020Guru - Experienced User
Potentially. tough to tell off the limited info you gave us.
If you're already got the extender and are trying to connect it, try setting it up using the installation wizard and not wps. It tends to work better with ISP supplied routers.
