Deehar
Mar 09, 2013Aspirant
NETGEAR WN3000RP-100UKS won't connect
Brought this after reading how easy it was to install, basically plug in, press button on extender than press large button on Super Hub(Netgear CG3101D) until it stopped flashing then it SHOULD connec...
Tombannister
Feb 28, 2016Aspirant
I am having the same problem it still not connecting is there any other way ?
DarrenM
Mar 03, 2016Sr. NETGEAR Moderator
Hello Timbannister
What is the issue you are having? Can you see the network but it fails to connect or can you not see the wifi network at all? Have you tried to change the security type to WPA2?
DarrenM
