Deehar
Mar 09, 2013Aspirant
NETGEAR WN3000RP-100UKS won't connect
Brought this after reading how easy it was to install, basically plug in, press button on extender than press large button on Super Hub(Netgear CG3101D) until it stopped flashing then it SHOULD connec...
Deehar
Mar 10, 2013Aspirant
jmizoguchi wrote: try using encryption (WPA, WPA2 ) instead of WPS
Security is set to WAP2-PSK :confused:
