Deehar
Mar 09, 2013Aspirant
NETGEAR WN3000RP-100UKS won't connect
Brought this after reading how easy it was to install, basically plug in, press button on extender than press large button on Super Hub(Netgear CG3101D) until it stopped flashing then it SHOULD connec...
Deehar
Mar 10, 2013Aspirant
jmizoguchi wrote: This setup is WPS and you are not using WPA2
Did you scan your network and put passphrase for WPA2?
WPS uses numbers to connect. Two different way to setup
Thank you for replying but I'm not tech minded when it comes to these sort of things - Not sure /how you scan network:confused:
