RogerBristol
Feb 20, 2020Aspirant
Netgear WN3000RP wont connect to website.
My Ipad and Mobile recognise the extender in settings with a "tick" but will not open a website. Have manually entered the DHCP settings for the extender and router but makes no difference. Have dou...
- Feb 21, 2020
At last. Switching off the power sockets at the control box for 10 seconds has worked. Recently, had been trying to link the wifi facility on a new TV recorder to the extender. Perhaps that was the interference.
Feb 20, 2020Guru - Experienced User
did you try resetting the wn3000rp and re-doing your setup? Mabye something was corrupted when rebooting the BT device. BT isn't known to be the best device :(
