RogerBristol
Feb 20, 2020Aspirant
Netgear WN3000RP wont connect to website.
My Ipad and Mobile recognise the extender in settings with a "tick" but will not open a website. Have manually entered the DHCP settings for the extender and router but makes no difference. Have dou...
- Feb 21, 2020
At last. Switching off the power sockets at the control box for 10 seconds has worked. Recently, had been trying to link the wifi facility on a new TV recorder to the extender. Perhaps that was the interference.
KevinJ_K
Feb 20, 2020NETGEAR Employee Retired
Hi RogerBristol,
Thank you for the message. Here is a link to the WN3000RP Frequnetly Asked Questions KB article:
https://kb.netgear.com/19070/WN3000RP-FAQs
You might also want to try and reset the extender. This can be accomplished by inserting a paper clip in the reset hole on the back of the unit and hold it until the extender status LED flashes amber.
Kevin K., NETGEAR Community Team
