RogerBristol
Feb 20, 2020Aspirant
Netgear WN3000RP wont connect to website.
My Ipad and Mobile recognise the extender in settings with a "tick" but will not open a website. Have manually entered the DHCP settings for the extender and router but makes no difference. Have dou...
- Feb 21, 2020
At last. Switching off the power sockets at the control box for 10 seconds has worked. Recently, had been trying to link the wifi facility on a new TV recorder to the extender. Perhaps that was the interference.
RogerBristol
Thanks Kevin. Meant to say had tried a factory re-set as you describe but no change. Will go to the FAQs.
Feb 20, 2020Guru - Experienced User
Did you do setup with wps or the installation wizard?
Try the install wizard instead of wps
- RogerBristolFeb 20, 2020Aspirant
Both, wps has always worked (BTHub 6) but also tried the installation procedure. Immediately told me I was successful, but still wont open a website. I have no problem using the router direct.
- plemansFeb 20, 2020Guru - Experienced User
did you try adding the extender mac address or setting a static route to the bt hub?
- RogerBristolFeb 21, 2020Aspirant
Me again. Yes, understand how to set a static route manually, in my case in an Ipad. Which IP address do I insert, is this the Ipad IP or the extender IP? I know my router IP address. Is the subnet always 255.255.255.0 ?
