christov
Jul 01, 2014Novice
Netgear WN802T - Cannot login
I've just purchased a second hand WN802T to extend my home wireless network but I'm falling that the first hurdle... can't even seem to get into the login page. I've scoured the internet for the bett...
jmizoguchi
Jul 01, 2014Virtuoso
Been a 2nd handed it is possible the issues are there but connecting AP and PC directly with PC static ip assign in lan subnet range like you did it should work
.233 should right or might 210. See some had wrong default ip in the manual
set pc as 192.168.0.1 and try it again
