GraemeBR
Jun 11, 2019Follower
NETGEAR WNDA3100-200PES N600 with a Panasonic Viera TX-P42UT30B TV
Hi i bought a NETGEAR 11AC 1200Mbps Dual Band Gigabit 802.11ac (300 Mbps + 900 Mbps) WiFi Range Extender with External Antennas and Extra Power Outlet works well I have a Panasonic Vier...
Jun 11, 2019Guru - Experienced User
looks like you posted this twice.
You can plug it into your tv but it isn't going to work. Both adapters are compatible with windows.
Your tv has a usb port but plugging a wifi adapter into it isn't going to make it work.
From the sound of it, you're trying to have better streaming. You could always hardwire the tv to the extender or even use a powerline adapter for a hardwired connection. Or you could purchase a smart device (roku, apple tv, android tv device) with built in wifi capabilities. Might be a route to check into as the Viera doesn't have a whole lot for smart features and you could get a decent roku and wireless capabilities for slightly more than a new wireless adapter.
