Chas_M
Apr 14, 2019Aspirant
Netgear X6S EX8000 connectivity - Resolved
Previously, I have experienced erratic connectivity of devices attached to my EX8000 extender. My basic network consists of a Nighthawk 9000 router with several wired and wireless devices. The EX80...
- Apr 24, 2019
Yes change from Auto to 1, 6 or 11 on the R9000 router.
Yes Smart Connect is desireable for the R9000.
If you set SC enabled on the R9000 then select enable One WiFi name on the extender.
Chas_M
Apr 18, 2019Aspirant
Coorection to my original posting.
While the direct connection of my devices to the EX8000 appeared to be reliable, I have found that it still from time to time drops the connections of the attached devices. This situation is unrecoverable unless a hard reboot is performed using the power off/power on cycle.
My firmware version is V1.0.1.192.
I am thinking of using a digital timer on the power brick to routinely power cycle the EX8000 every 24 hours to ensure a reliable conenction as a workaround for this inherenct defect in the EX8000.
I also notice on the status page with the green diagram that both the 5GHz (Channel 9) and 2.4 GHz (Channel 44) bands show there are no connected devices. However, the list of connected devices shows there are 7 wired devices connected.
Please let's have someone provide some reliabel information about how to resolve this connection dropping situation so this expensive device can be trusted.
