Chas_M
Apr 14, 2019Aspirant
Netgear X6S EX8000 connectivity - Resolved
Previously, I have experienced erratic connectivity of devices attached to my EX8000 extender. My basic network consists of a Nighthawk 9000 router with several wired and wireless devices. The EX80...
- Apr 24, 2019
Yes change from Auto to 1, 6 or 11 on the R9000 router.
Yes Smart Connect is desireable for the R9000.
If you set SC enabled on the R9000 then select enable One WiFi name on the extender.
Chas_M
Apr 22, 2019Aspirant
So far it is working without any disconnects. I have no understanding why the system seems to be rock solid in its capabilities. Channels being used are:
Router to extender:
2.4 GHz, channel 9, 192 Mbps
5.0 GHz, channel 153, 1733 Mbps
Extender to device connections:
24 GHz, channel 9, 400 Mbps
5.0 GHz.channel 44, 867 Mbps
I will consider your channels suggestions if the Extender becomes problematic again.
Apr 23, 2019Guru - Experienced User
channel 9 is not a good channel to use on 2.4Ghz. 1, 6 or 11 or 13 are primary channels to use.
Good Luck.
- Chas_MApr 23, 2019Aspirant
Thank you for the suggestions. These channel assignments were setup automatically during the WPS connection process for the router to extender connection. Should I change from channel 9 on both the router to extender connection, and also on the devices to extender connections? Looking at the channel activity in the neighborhood with WiFi Explorer, it looks as if channel 9 is in the middle of a very busy part of the spectrum. In fact, I now notice that WiFi Exporer is warning me about overlapping channels. I will probably try channel 13 since it does not appear to be as congested.
- FURRYe38Apr 23, 2019Guru - Experienced User
Just change the main host router only. If the EX is extending wifi from the main host router, then it will follow to the channel you select on the main host router. Channel 13 would be good too.
Thank you for your help. On looking at the NG x10 9000 router settings, I notice that the 2.4G network channel selection is set to AUTO. For the extender connection this is defined as Channel 9. Also, the highest channel permitted on the router is Channel 11 not 13 with up to 800 Mbps. Should I change from Auto to another channel other than channel 9?
I notice that the Router wireless setup shows that Enable Smart Connect is checked - is this desirable?
Should I select Enable Smart Connect for the Extender as well? I had read on another posting that Smart Connect was not a desired mode of operation for an extender.
Finally, would you recommend that I enable One WiFi Name on the Extender? Currently it's disabled so I have the -2GEXT and -5GEXT suffix added to the name.
I really appreciate your help on this matter so that I can get a good releable system.
Charles
