Chas_M
Apr 14, 2019Aspirant
Netgear X6S EX8000 connectivity - Resolved
Previously, I have experienced erratic connectivity of devices attached to my EX8000 extender. My basic network consists of a Nighthawk 9000 router with several wired and wireless devices. The EX80...
- Apr 24, 2019
Yes change from Auto to 1, 6 or 11 on the R9000 router.
Yes Smart Connect is desireable for the R9000.
If you set SC enabled on the R9000 then select enable One WiFi name on the extender.
Apr 24, 2019Guru - Experienced User
Chas_M
Apr 24, 2019Aspirant
Thank you all your help. I have learned a lot about the network and the relationship between the router and extender. I finally chose channel 1 based on neighborhood network activity to avoid competing relatively high power channels from neighbors that would overlap with my channel 1. Other changes were made for Smart Channel and One WiFi name.
Everything worked as you said it would without any problems. I will let you know if problems show up over the next few days.
Thank you so much for your help.
