doco12uk
Jan 24, 2012Novice
network drops :(
Ok so i have 5 machines connecting wirelessly through a WNR2200 and 1 machine wired to a cable modem. everyone connecting without wires notices significant drops in connection speed and network stren...
jmizoguchi
Jan 24, 2012Virtuoso
if same location has not caused any issues and there isn't any significant channel issues then you may could have wireless going bad
I would hard reset the route and see (see router reset on my sig below)
if the unit is still under warranty then you may want to contact support my.netgear.com
