rgiorgio
Dec 20, 2020Tutor
Network Extender + Yamaha Receiver
I have a Yamaha R-N303 network steroe receiver. It is ethernet plugged into a Nighthawk Network Extender.The receiver wont connect to my network to setup. My network is not showing the Yamaha receive...
Dec 21, 2020Guru - Experienced User
If you plug a laptop/pc into the extender, does it work?
Trying to determine if its an extender issue or a recieve issue
rgiorgio
Dec 21, 2020Tutor
It does not
Also, the yamaha receiver worked on another network with no extender
- plemansDec 21, 2020Guru - Experienced User
What router is the extender connected to?
Firmware on the extender?
Did you setup the extender using WPS?
- rgiorgioDec 21, 2020Tutor
Nighthawk R7800
Firmware has been updated
I dont recall how extender was installed, its been in use for a couple of years
What extender do you have and what firmware? These are keys as "up to date" isn't always the best.
What gateway are you using?
If you've had it for years, did it work before? did it stop working?
did something happen to stop it from working?Is it only wired that isn't working?
