justin619
Mar 27, 2020Aspirant
Network Extension
I have recently started my office, looking to extend my network to different rooms. I am thinking of setting up WiFi for each and evry room individually. What could be the best way to achive the sa...
Mar 27, 2020Guru - Experienced User
how many rooms?
You could always go with somethink like orbi
justin619
I have the main WiFi router in the middle room which is kind of meeting hall / conference hall.
After that, I have 8 rooms surrounding the hall.
So it is something lke that.
Thanks
- plemansMar 27, 2020Guru - Experienced User
I've read of people using up to 6 orbi satellites.
And you HAVE to have one in each room?
That's a bit expensive and would put the satellites to close to each other as they recommend 30ft between satellite/router
