debas's avatar
debas
Network range extension to other building
Newbie here so please be patien .  I have a Cambium Router that was installed with my internet service (I had no choice).  I want to extend internet service from my house to another building about 90 ft away here on the ranch.  Currently I get a limited signal in the closest corner of the outbuilding.  If I add an extender in that room will that give me service in the other 1800 sf of that building ?  If so, which extender do you recommend ?  Thanks so much !
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello debas
    Yes it should give more signal if it can keep a solid connection in that cornor of the building. 1800 sq feet is large so it may not cover it all just depends on the environment.
