rangeview
Aug 12, 2020Follower
Network Security Key not the same as router
I was able to connect my router to the extender using the WPS button and the extender is now visible as a wifi option on my laptop. However the network name of the extender (6054) is not showing the...
Aug 13, 2020Guru - Experienced User
What firmware is on the extender? The mesh option was added in version 1.0.1.86.
What router is it connected to?
What I'd recommend?
Start by updating the firmware to the latest version on the extender.
Once updated and rebooted, factory reset the extender back to factory.
Then re-install it but using the installation wizard and not wps.
WPS can get coded different between different manufacturer's and this can cause issues. So try the install using the wizard.
the firmware, manual, and install guides can be found here: https://www.netgear.com/support/product/EX6150v2.aspx
