beaker13's avatar
beaker13
Network Security Key
Hello,
I believe I have the extender logged in (connected to?) the wireless router.
When I go to log onto the "extender network," it asks me for my Network Security Key.
How would I go about finding that information?
Thank you for your help.
  • Hi beaker13, that should be your WiFi password. You can try using your main networks WiFi password if you set it up that way during the installation.
    Dexter
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Dexter
    • beaker13's avatar
      beaker13
      Thank you, Dexter. My issue appears to have been solved :)
