BlueMax_23
Nov 27, 2021Aspirant
New AX1800 can’t find router during initial install
I'm trying to install the AX1800 WiFi mesh extender on my network. It keeps indicating that it can't find the router, thus there is no internet and the installation process stops. The router is of ...
Nov 27, 2021Guru - Experienced User
What actual extender do you have? AX1800 is a speed.
Did you set it up using WPS or the installation assistant?
- BlueMax_23Nov 28, 2021AspirantThe model is EAX14. I have tried the nighthawk app and WPS.
I am also finding that I lose internet connectivity whenever I try to add the extender. As soon as I remove it’s power the internet connectivity returns.
My router is a TP-link AX4400- plemansNov 28, 2021Guru - Experienced User
what firmware is on the extender?
Try factory resetting the extender and installing it using the installation assistant.
Don't use wps or the app.
