DanaClark
Jan 18, 2021Follower
New Extender EX2700 Unable to connect
I'm trying to set up our new Range Extender. The manual method doesn't seem to work. When I enter the URL they tell me to, I don't get the NEW EXTENDER SETUP as the instructions say, but rather "You are not connected to your extender's WiFi network". Any suggestions?
1 Reply
Hi Dana,
The N300 WiFi Range Extender Model EX2700 Quick Start Guide does state...
"Connect with the NETGEAR Installation Assistant
1. Use a WiFi network manager on a computer or mobile device to find
and connect to the extender WiFi network NETGEAR_EXT. *
After the connection with the computer or WiFi device is established,
the Device Link LED lights.
2. Launch a web browser.
3. Enter www.mywifiext .net in the address field of the browser.
The New Extender Setup page displays...."* The security key/password for the NETGEAR_EXT is printed on the product label.
This should allow to establish a wireless connection to the extender. If the coputer does state there is no Internet connection, allow it to retains the connection without Internet access.
