JitM
Apr 29, 2021Aspirant
New Home Network Suggestion
Hi All, Apologies in advcnce if I am posting this message in wrong group. I am currently using RBR50 & RBS50 at my home as Wifi Mesh system. It works perfectly fine though sometime my Satelli...
Apr 30, 2021Guru - Experienced User
You can use your current system with them.
What is Ethernet backhaul and how do I set it up on my Orbi WiFi System? | Answer | NETGEAR Support
It works great. Plus you can add additional satellites if needed to expand you coverage.
