kharvey91
Nov 22, 2023Tutor
new modem and router, existing EX6100 v2 and EX6150v2 won't connect
I was having spotty wi-fi, so replaced my Spectrum modem and my wifi (purchased a TP-Link Archer AX3000). They are both set up and I now have blazing fast wi-fi again. But I can't get my two range ex...
- Nov 23, 2023
WPA2/WPA3 mixed mode *should* be fine. But if you have an option, try wpa2. I've seen a couple of implementations of mixed mode that had issues.
kharvey91
Nov 23, 2023Tutor
Ooooh, that’s an interesting angle I hadn’t considered. I’m using the mixed WPA2/WPA 3 on the AX3000 router. Is that an issue for the extenders?
Nov 23, 2023Guru - Experienced User
