jettrt
Mar 25, 2020Aspirant
New router - still dead spots
I just bought a Nighthawk X6S AC4000 Tri-band Wi Fi Router and installed it to my Frontier Fios Modem. Moved both to top of cabinet, (from inside bottom) in front corner of house because that's where...
Mar 26, 2020Guru - Experienced User
A newer router isn't necessarily going to provide further coverage. Reason why is they're limited in how much power they can broadcast with by the FCC.
Your best router is to optimize placement or add an range extender.
I'd recommend moving the router to the middle of the home if possible. I know you said you cant but sometimes, paying someone $50 to run a cable/line is a better option than buying an extender as it'll work long term.
Reason why is that routers are omnidirectional. Meaning the broadcast in basically a circle. If you're router is on one side of the home, basically half the broadcast isn't covering the home.
And the RE300 should work. Try and set it up using the browser method and not the app/tether instructions. You also might have to disable its mesh function. But you can try it.
jettrt
Mar 27, 2020Aspirant
Thanks so much. Talked with Frontier today and improved signal when they disabled wifi from modem. She also suggested moving to center room but also thought an additional plug in the wall extender upstairs might help get the signal to the back room. This is an turn of the century solid wood and lathe wall house with brick chimneys so not surprised dead spots. Do you think that would help and if so which specific device. I had previously bought a tp-link that did nothing then the $300 nighthawk.
- plemansMar 28, 2020Guru - Experienced User
I would try contacting tp-link to get the extender working. Its a pretty good extender to pair with your router
