AprilB
Feb 13, 2018Aspirant
New Virgin Media Hub - The EX2700 connects to wifi and works but is not protected
Hi I have recently had a new Virgin media Hub, was able to get the EX2700 connected to the wifi and it works but it is not protected! When I go to login in to go to the Extender settings the login us...
AprilB
Feb 14, 2018Aspirant
Would love to change my password but it is not giving me option to - this is all there is on screen!
DexterJB
Feb 15, 2018NETGEAR Moderator
Hi AprilB,
If that is the case, then a factory reset mentioned in my previous response can be an option. This will allow you to reconfigure and setup the extender.
Dexter
Community Team
- DexterJBFeb 19, 2018NETGEAR Moderator
Hi AprilB,
Resetting the extender will require you to push the reset button with a pin or a paper clip as instructed on the user manual. If you are asking about setting up the extender, then yes, you can set it up via wireless also using the guide on the user manual.
Dexter
Community Team
