KnoxMc
Aug 06, 2020Follower
New wifi router
I got a new wifi router. I can't hook my nighthawk extender up to it. Can't find any guidance anywhere. Can anyone help? Thanks.
Knox
1 Reply
What router did you buy?
Here's the support site with install guides: https://www.netgear.com/support/product/EX8000.aspx
I'd recommend using the installtion wizard method and not using wps for setup.
