summersgill
Mar 03, 2021Aspirant
Nighhawk x4 AC2200 Wifi Range Extender
So tNighhawk X4 AC2200 WiFi Range Extender stopped working abouta year ago for no apparent reason and we seemed to manage without it. Now we can't and it refuses to work. We've tried going on line a...
Mar 03, 2021Guru - Experienced User
We'd need a little more details.
What are the led's on it doing? (color, blinking, solid, etc)
What router are you connecting it to?
are you setting it up using wps or using the installation assistant?
Did you try a factory reset? (push and hold reset for 7-15 seconds while its fully powered on)
What firmware version is on it?
here's where you can find firmware, manuals, guides.
