tomboc
Feb 09, 2025Follower
nightgear AC1900
I have not been able to connect my nighthawk ac1900 wifi range extender to my deco x55 mesh system. Can anyone offer any suggestions how to do this. The neatgear has worked great with a standard netg...
Feb 10, 2025Guru - Experienced User
A couple things.
1. what actual model do you have? AC1900 is a speed
2. what firmware is on it?
3. what method of setup are you using? WPS? The app? The installation assistant?
4. What error does it give you or what are you seeing when you go through setup?
5. what are the leds on it doing?
