dolfin67
Aug 08, 2020Aspirant
Nighthawk AC1900 desktop wifi extender (EX7000-100 NAS)
I have the above listed model of wifi extender which worked 2 days ago and now is undiscoverable by my wifi hook up. All lights are green and working. The extender has not been moved. It just stopped being recongnized. I have shut off the internet and reconnected, still nothing. I go to the app and it can not hook up because there is no netgear address to be found. Help!!
Thanks!
Dawn
1 Reply
What router is it connecting to?
What firmware is on the extender?
What are all the leds on it doing? color/blinking/solid
If you hardwire into the extender (disable wifi on whatever device you connect to it), are you able to access the extender via the
mywifiext . net?
the support site with manuals, firmware, guides is here: https://www.netgear.com/support/product/EX7000.aspx
